1 - 3 of 3 Posts
Im a noob im goning do my first oil change and I was just wondering what kind of oil and oil filter I should be using. I know that i need synthetic oil and thats about it and also what brand is better.
P.S i have a 07 GTI 2.0T(obviously) thanks guys http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Re: what kind of oil?? (scryed77)
There's lots of information in this group. I suggest you start here:
http://forums.vwvortex.com/zerothread?id=3851335
Long story short, the most commonly available oils that meet the 502.00 oil specification that VW REQUIRES for your car area as follows:
Mobil 1 0W-40
Castrol Syntec 5W-40
Castrol Syntec 0W-30
Valvoline SynPower 5W-40
That said, there are lots of other 502.00 (or better) approved oils from the likes of Motul, Elf, and many others that can usually be found via the internet.
A word of caution; make sure that the oil you use is "Approved" by VW and/or Audi and not just "Designed to meet or exceed" the VW oil specs. If you use the latter and have an engine problem, there is a good likelihood that your warranty coverage will be jeopardized.
1 - 3 of 3 Posts
