What kind of spark plug?
448 Views 9 Replies 7 Participants Last post by  SaabFan
I am wondering what type of spark plug should I use in my 92 Passat Wagon G60? Bought the car a little while ago, but not sure when the plugs were changed.
1 - 10 of 10 Posts
Re: What kind of spark plug? (Raine)
bosch w6dpo........
ps try the search next time
Re: What kind of spark plug? (Strictly Gravy)
i'd first just use a wire brush and brake cleaner and remove all the carbon and make them shine, then if the car is misfiring or something, replace them. They are meant to last a long time unless damaged. Check the ceramics they should be a reddish/brown color , white = bad. specks of aluminum = bad.
alot of peeps replace things that dont need them, cleaning plugs is a regular event imo.
wires/rotor/dizzy cap, spend your $50 on that first.
Re: What kind of spark plug? (mrkrad)
ngk ... end of story
Re: What kind of spark plug? (GotEuroCorrado)
quote:[HR][/HR]ngk ... end of story[HR][/HR]​
Not for a g60. They tend to run best on the factory-specified plug, which is the Bosch unit listed above.
-Nate
Re: What kind of spark plug? (SaabFan)
-Nate[HR][/HR]​
I am big fan of stock Bosch too.
Just not anything Platinum i have had so many problems with it, Remember save the Bling Bling for your mouth!!!
Edit: I type at a 2nd grade level!!!
[Modified by n19bmw, 1:20 PM 3-27-2003]
Re: What kind of spark plug? (n19bmw)
im not talkin the platinum ngks.. just he reg ones. they seem to outlive the bosh in t he vr6 i would think that would be the same in g-60.
quote:[HR][/HR] they seem to outlive the bosh in t he vr6 i would think that would be the same in g-60.[HR][/HR]​
It's not.
they're two very different engines, and though the ngk's work excellently in the vr6 application, the stock Bosch plugs are by far the best choice for most people with the g60 engine.
-Nate
See less See more
Thanks guys I thought a passat owner would get yelled at postin here, but when you need to know about G60's theres only one place to go. Thanks.
See less See more
3
Re: What kind of spark plug? (Slavious)
quote:[HR][/HR] but when you need to know about G60's theres only one place to go. Thanks.
[HR][/HR]​
*cough*the g60 forum*cough*
Granted, most of the people that hang in the g60 forum check in here too, but if you have technical g60 issues, that's definitely the place to head. Lots of very helpful people in there all the time, even if it moves a bit slow sometimes. http://****************.com/smile/emthup.gif
-Nate
PS - Be proud of your Passat! They're very cool vehicles!
See less See more
1 - 10 of 10 Posts
