ICurious to know what numbers people are getting at the wheels or crank with a naturally aspirated 3.6 VR6 and what they did to get them.
Supersprint Headers
High Flow cats
Cold air intake
Tune
Porting
Flex fuel mods
I'm also in the process of putting together a supercharger kit for the 3.6 4motion models as well. Going off of how they used to do them with the Eaton M90's on the 2.8 I'm thinking of using the Eaton M122 off of a 4.6 cobra.I
I have a scanner that reads HP/TQ
AND I'm getting about 253 to the wheels
And I got smoked by a 128i for comparison, I think the drivetrain loss is even worse because a 128 comes from the factory with 253. And I didn't catch him until we hit 90mph. Maybe because I had a passenger idk CC's are heavy.
I
253 at the wheels is pretty respectable. Surprisingly the 128 is only a couple hundred pounds lighter than the CC with less power at the wheels. Sure it wasn't a 135i, that car has 335hp and is quick as hell vs the 230 of the 128. Do you have a DSG tune or are you shifting manually? My guess is that if you had a haldex and DSG tune that the results would have been verydifferent.
I have a matching set of 08 VR6 audis, a DSG A3 and a manual TT. The TT is significantly quicker than the A3 but it's also 600lbs lighter. Thinking about doing an engine swap to a 3.6 in the A3 because I want to stay naturally aspirated and trying to figure out if it's worth it or whether I should just do cams. The most I could hope to get out of the 3.2 is 280hp at the crank, I've heard of some people getting 315 with the 3.6.
If you have the average drive train loss that would put you up over 310 at the crank. My A3 has 245 at the crank and I only get about 187 to the wheels.
I can attest to that, though not apples-apples comparison as I have a wagon. Neighbor has a B6 FWD Passat while I have a B6 4-Motion. He is considerably faster (aside from my initial launch benefit). Additional weight and drivetrain losses certainly show.Side note, met a dude at RDM with a stanced b6 4motion 3.6 and we lined up quite a few times just for fun and i always beat him. The 4mo is like 600lbs heavier or something
Forgot to respond but I found a better approach to my forced induction project .. Precision 6262 turbo. Compression won’t be an issue the guys who use 3.6 blocks don’t even bother with spacers. Company in Jersey RAI built one with twin GT35R’s and the stock block safely handled 750 HP @14PSI with proper cooling. I have an aftermarket intercooler from a 2.0t cc and trying to get the Forge Twintercooler soon. Those two plus a water meth kit will easily and safely make 750. The RAI car makes 700. I’m trying to make the CC 4Mo the next tuner.. they look better anyways! And this route is cheaper than anything you’ve seen on the internet soon as I’m finished with the build I’ll have a full write up!What are you going to do about the compression ratio? Thicker gasket?
Sent from my Moto Z2 Play using Tapatalk
Absolutely True. I have a 09 CC 9M AT VR6 Sports FWD. I do have some mods: Unitronic Tune, FORGE Airbox Intake and Straight pipe catback with Borla XR-1 Mufflers.'06 3.6 fwd here with the 09G 6spd trans, I've never put her on a dyno but I'm certain I've got at least 280 at the wheel maybe more...... Im not sure why the R36 has a higher displacement but all around the fwd 3.6 feels like a 300hp car.
