1 - 18 of 18 Posts
What problems have you had with your Jetta? I had so many problems and wanted to know if you had the same problems.
http://****************.com/smile/emthdown.gif http://****************.com/smile/emthdown.gif
Thanks
Re: What problems have you had with your Jetta? (2k3TitaniumSE)
All coils replaced twice,
Window regulators failed
Front seat frame replaced
Radio going out
Armrest pealing
Lower than expected gas milage
The creaks and rattles that I have really don't bother me all that much.
Bought my '00 Jetta in '02: Replaced transmission, window regulator, airbag sensor in passenger seat, tensioner pulley, engine and tranny mounts, and A/C hoses. All were dealer faults, and I'll drive my Jetta "til the doors fall off".
quite a few with 2000 GLS
both rear wheel bearings replaced
wiper bearing seized
water pump replaced
MAF sensor replaced
CD changer died
antennae corroded at roof, replaced base
All happened between 40,000 and 90,000 km (ie out of warranty)
Still waiting for MAF refund
From 90,000 to 160,000 only needed routine maintenance, tires, brakes, battery, etc
Average for reliability, but the best car I've ever owned for driving fun!
Re: quite a few with 2000 GLS (vr6cylheaven)
here's my list:
abs unit replaced
all coils replace with Js
rear right window "motor"
both front window regulators
purge valve
coolant reservior (coolant level sensor)
gas gauge (twice)
basically I've had the run of the mill problems only http://****************.com/smile/emthup.gif
Re: quite a few with 2000 GLS (samc)
My radio screen doesn't work... [Dealer ordered new radio]
My ESP won't turn on... [Dealer ordered new part]
Two CV boots...
One axle...
Winshield wipers are very loud/annoying...Blade fell off two days ago after being replaced once already...
Emergency brake handle comes right off revealing a metal stick... [Told dealer, they gave me a new handle but it still comes right off? lol]
Crappy jack tore a 1" hole in my sideskirt after the car fell off it...Good thing I still have my arms.
But, to tell ya the truth, I love my Vdub
. Oh yeah, also I only have 9,200 miles on my car.
Modified by Duren at 12:56 PM 2-17-2004
1. Cracked PCV hose. Replaced under warranty at the 40,000mi service.
Um...yeah.
I also had the coils & window regulator clips replaced but got those done at my 35,000mi oil change before they failed so they weren't really "problems" per se.
And that's the end of that chapter!
Re: What problems have you had with your Jetta? (jddaigle)
5 Coils
1 purge vavle
Bypass vavle
turbo hoses???
2 coolant temp sensors
ABS unit
Premature rear brake wear 33000miles
Win reg
Center vent not working
1 fuse took out CC, heated seats and A/C
Heating control light bulb.
Shifter problems - going into reverse sometimes & 2nd gear grind.
SHHHH, be very quiet, my cars might hear this... I haven't had any problems...
Cheers
V
All I've had go wrong is a failed brake light switch. So far.
(Knock on Wood)
Replaced Starter
Replaced Burnt out Gauge Cluster
Shifter Grinding in every gear (appointment tommorow)
Chirping at Idle (appointment tommorow)
All covered under warrenty so far! Hopefully the grind fix will be aswell!
Banned
Re: What problems have you had with your Jetta? (Passetta00)
ive only had my car like 3 weeks and ive had my check engine light go on ( yes i checked the gas cap) and had the stereo go into "safe" mode when i have the heater all the way on. just put in a new pioneer deck and the check engine light has gone off, so most of it is just annoying stuff
Re: (AllCityDubs)
Rear brakes
MAF
02 sensor
Faded antenna mast
Drivers side window regulator
AC control light
Cam shaft position sensor
As we speak, at the stealership, water pump/timing belt.
The cluth was broken in 3 parts with one week of having taken out of the dealer
1 - 18 of 18 Posts
