1 - 6 of 6 Posts
I know it is not the worst bent wheel, but the tire is bubbled on the other side.
So, do I definatley need a new tire? And is this un-safe whether I leave the tire on or get a new tire?
Should I get it fixed? If so, where? or do I get a new wheel? or do I leave it and get a new tire and hope it seals?
Thanks
Re: What should I do about this? - bent wheel question (4ank)
if the bead is not bent as well then you don't need to fix the wehel...but an egg in the tire means get a new tire
Re: What should I do about this? - bent wheel question (JPawn1)
How do I tell if the bead is bent?
Quote, originally posted by JPawn1 »
precisely.
the bend doesnt look bad at all.. as long as it will hold air it looks more then fine
usually, if the bead is bent you won't be able to hold pressure in tire or you will have a sloww leak.
1 - 6 of 6 Posts
