Which should I get, Eibach Pro System or Pro System Plus?
The Pro System Plus includes Eibach 22mm front & 25mm rear swaybars. Is that much difference than the factory swaybars on a GTI 1.8t ('01 or '02)?
Thanks,
Ming
Re: Which should I get, Eibach Pro System or Pro System Plus? (MingS4)
quote:[HR][/HR]By "integrated", do you mean it can't be removed? So that any aftermarket rear bar is in addition to the stock "integrated" bar?
Thanks,
Ming[HR][/HR]
The rear bar is welded into the rear axle. Technically, you could probably remove it if you have to. But, all rear sway bars are designed to be installed while leaving the stock bar in place.
VW Vortex - Volkswagen Forum
