1 - 8 of 8 Posts
I am replacing the oil cooler o-ring, and I need to know the size of the nut holding it on as I do not have the appropriate sockets.
Thanks for the help!
Discussion Starter · #4 ·
Re: (youlostme21)
I tried an adjustable, there's no way that will work, there are hoses and lines all over, it would be much easier to use a socket, but I don't know the correct size of that nut...
anyone know for sure?
Re: (youlostme21)
Quote, originally posted by youlostme21 »
Just use a large adjustable wrench. Its easier to get at that way then wiht a socket, due to the radiator support being right there.
thats what i used a few weeks back, no room for a socket
honestly i used a socket,an extension, universal, and it was fine, i was in a 2.0aba dont know if this a vr or not... but yeah... make sure you don't damage the hollow shafter when you unscrew it off the housing good luck!
edit: you need a deep socket in order to get to it.... and it doesn't take much for to get it off
Modified by q_ball2 at 6:45 PM 1-29-2010
1 - 8 of 8 Posts
