1 - 3 of 3 Posts
what is the lowest profile tire i can get for a 16x7.5 wheel without stretching? (post pics if you can)
Re: what size tire for 16x7.5? (Fallacy)
profile and stretching are two different things.
Profile- is the height of the sidewall (ratio between tread width and sidewall height- the middle number XX\45\XX)
NOTE- when playing with sidewall height you can make your speedometer inaccurate
Stretching is when the width of the tire is smaller than the rim- No stretch would be a 205mm wide tire on a 7.5in rim, any smaller would be stretched- The tire width is the first number 205\XX\XX
The ideal tire for a 16x7.5 is a 205/45/16
Modified by mack73 at 3:58 PM 2-14-2004
Re: what size tire for 16x7.5? (mack73)
yeah, 205 width is what you want if you don't want stretch.
1 - 3 of 3 Posts
