I asked this question in the manual tech forum with no info,maybe you fellas can shed some light.
What vss/speedo sensor setup can i run so i can use my stock mk3 cluster? is there a g60 vss/speedo that has the electrical provision for the 2l wiring harness plug so i can just run the mk3 2l gauge cluster?
Is there any way to setup the stock vss/speedo 2L from the 020 in the 02a to run the stock cluster in the mk3?Any information is greatly appreciated,thanks in advance
