Re: What Times do you G'd up people run the 1/4 in (BLUE NRG)
my friends bunny w/ g-60 swap runs 13.9's on street tires at 98 mph w/ a 2.2 60 foot time (blowing tires off the whole way).
here is his setup
1990 Corrado G60 swap, charger has a mod 1 rebuild. the block has new rings, and bearings. cylinder head was re-done to stock specs. Autotech stage 3 kit, Eurosport intake kit, Saab 900 turbo inter-cooler top mounted w/ custom heat shield, jackson water system also added. Autotech boost check valve. ABD plug wires.
Exhaust:
Autotech tri-y header, Techtonics 2 1/4 stainless steel cat back w/ a Borla muffler
Transmission:
AGB code 16V trans w/ full rebuild. Quaife diff, HOR Technologies 3.94 ring and pinion, VW Motorsports bearings, seals, and syncros. stock 16v gear set.
he has since added some goodies (bigger injectors, different chip) since he last ran at the track, not sure if he is keeping the motor though. Might build up a 16v turbo and put that in, even though he just finished this one last summer b4 carlise. So if u went to carlise, it was there- the yellow rabbit no where near vw's, but in the wild section or whatever.
