1 - 13 of 13 Posts
Discussion Starter #1
My stock tires were mushy around sharp corners, so now I'm running 35 all around. Can I go higher, or is that stupid?
What do you have your tires set at?
Re: What tire pressure are you using? (vchadaga)
35 all around
Discussion Starter #3
Re: What tire pressure are you using? (E36BMW)
glad i'm not the only one http://****************.com/smile/emthup.gif
UK Sport models running on 17" is listed at 37 all round.
This is what I have...no problems at all
Quote, originally posted by E36BMW »
35 all around
ditto
I am at 40, call me crazy but it is damn hot here and so it might just be fine
35 all around
...per Tire Rack's recommendation.
You can set your tires wherever your butt dyno says they should be at, as long as it's less than the max pressure listed on the sidewall.
The inflations recommended by VW (or any other maker) are a compromise between safety, performance and comfort. Feel free to experiment. A performance driver is going to be happier at the high load/high speed settings. Also remember that you'll get better mileage with harder tires, perhaps noticeable perhaps not.
Re: What tire pressure are you using? (gerald)
What are the pressures recommended by VW anyaway? Are they following the stupid new rule in the U.S. that they are supposed to list only the max load pressures?
1 - 13 of 13 Posts
