ok well it finally happened. my 1600cc used engine i bought for $300 went south.(3 years later) it lasted a long time considering it was suppose to be a temporary motor. i decided on going with a 1776cc this time around because i have had one before but it was just a stock 1776 which ran well but the case had a crack in it and everything went wrong. so i bought the used 1600 and now i am here. what i would like to know is what should i use to get the most bang for the buck for this engine. i want to be able to drive it daily, run at decent temps and be able to stomp the occasional honda here and there!
can you give me some suggestions on the type of cam, heads, rocker arms, flywheel, clutch, and whatever other parts will make this engine last and rock at the same time. i am already planning on balancing everything, port and polish, full flowing it, traction bar, and using my dual kadrons carbs on it. if anyone can give me some nice specs or ideas on what to use or what they have used or are currently using i'd greatly appreciate it.
