Status
Not open for further replies.
1 - 20 of 60 Posts
2006 P+ A4 3.2 Avant, 2011 C'Dale Bad Boy, 2014 C'Dale Carbon Synapse, 2019 P+ Q5
Re: what vortexer(s) has the fastest 16v? (joeZX6)
100% streetable. When this thing is running it is scary
2L 16v with Eaton in a Rabbit
probably not the fastest in the world but pretty quick
I had the title for a while with a 12.56/110mph from a 1.8 daily driver,then I sold my system to oversteervw and we put it on a 2.0 and he's going faster at 11.92/114mph still a state inspected daily driver.
Re: what vortexer(s) has the fastest 16v? (Hardcore VW)
who is MANNY?!!? check out vwsport.com and the manny drags. its a blue jetta. it was runnign 14's i think but it was smoking monte carlo's, mustangs, camaros. it was nuts
Discussion Starter · #6 ·
Re: what vortexer(s) has the fastest 16v? (16v)
quote:[HR][/HR]100% streetable. When this thing is running it is scary
probably not the fastest in the world but pretty quick[HR][/HR]​
is it yours? how much boost? what does it run in the 1/4 mile?
[Modified by joeZX6, 1:37 PM 11-30-2001]
That blown Rabbit is just sick!
(I think that's the word they use these days
Forum member 'Scrick GTX' ran a 14.1 N/A http://****************.com/smile/emthup.gif
not mine... runs 6lbs or so and has never been to the track.
Quickest where? In the 1/4? On a 'horsepower track' (IE Laguna Seca) with sweepers? In the hills with lots of tight, bumpy switchbacks?
Guess who always gets to the top of the mountain first...
Discussion Starter · #11 ·
quote:[HR][/HR]not mine... runs 6lbs or so and has never been to the track. [HR][/HR]​
do you know what he dynoed at?what is he using for fueling(fpr,injectors,chip)? what can make more peak h.p. a 1.8 16v or a 2.0 16v....i ask because ive heard that the 2.0 are more for torque and the 1.8`s are more for h.p. but i dont know if this is true
oversteer has around 300 whp with a 16vT lets hope he comes in here....he runs 12.7's with street tires and 11.9's on slicks...he lives in NJ
Re: what vortexer(s) has the fastest 16v? (tt16v)
I don't think this was directed to me or oversteer,but it's our numbers,so for the record,we have his car at the track on a regular basis.
· Premium Member
here's Schrick GTX's timeslip and dyno charts:
14.16secs
167hp at the wheels
he's selling that engine and building something......FASTER
he also ran that 14.1 with some sort of a misfire and running lean around 7000rpm, as seen in the dyno.
Re: what vortexer(s) has the fastest 16v? (The Red Baron)
thanks gareth!
14.1 @ 96 mph
167 hp (N/A) at the wheels
actually, the whole car is now for sale.
i'll be hooking up the classified ad ASAP.
Discussion Starter · #19 ·
Re: what vortexer(s) has the fastest 16v? (Schrick GTX)
what happened on the dyno between 7100 and 7600? was it because you were running lean? what kind of fpr and injectors were you running?did that engine have a fuel rail?
quote:[HR][/HR]thanks gareth!
14.1 @ 96 mph
i'll be hooking up the classified ad ASAP.[HR][/HR]​
quote:[HR][/HR]what happened on the dyno between 7100 and 7600? was it because you were running lean? what kind of fpr and injectors were you running?did that engine
have a fuel rail?[HR][/HR]​
i was running a bit lean due to a plugged fuel filter and basically not enough fuel mapping in the chip. i've compensated with richening it up across the whole range, but it's not exactly how i wanted it... garrett has not really proven that he has much interest in customer suport, so i can't really expect much help from him.
i'm using audi 200 turbo injectors.
no fuel rail, stock cis-e motronic (with a "custom" [HA] garrett chip).....
1 - 20 of 60 Posts
Status
