1 - 5 of 5 Posts
I had an alignment done on my car about 3 months ago and now it's trippin out on me. I haven't really hit to many potholes, not enough to screw it up I think. Now, just today, the wheel pulls on the freeway from side to side once in a while (it's kinda trippy) and I have to turn the wheel a lot more to make a normal turn. Do I need another alignment??
Re: Whats goin on here?? (ThisAin'tNoCivic)
If your tires were older when you had the alignment theres a good chance your tires were already worn with the improper alignment.. This being said theres a good chance your tires are causing the car to track improperly.. I imagine if you aligned your car with new tires this problem could be eliminated.. I had the same problem, and this was the solution for me..
Discussion Starter · #4 ·
Re: Whats goin on here?? (SilverMkII)
the tires are basically new, maybe need a rotation. What do you think could be bent? maybe my lower stress is jacked
hey,havnt talked to you in awhile man? You finish up the front end?
1 - 5 of 5 Posts
