Whats the difference between the audi 225 hp 1.8T and this years 180 hp 1.8T?
1140 Views 13 Replies 10 Participants Last post by  wolfinblue
Higher psi boost? puter chip? exhaust? intake? and don't say horsepower
1 - 14 of 14 Posts
Re: Whats the difference between the audi 225 hp 1.8T and this years 180 hp 1.8T? (miked197474)
horsepower
i was wondering the same thing
See less See more
larger turbo, and dual intercoolers, for starters.
Re: Whats the difference between the audi 225 hp 1.8T and this years 180 hp 1.8T? (RocketVR6)
Dual intercoolers...theres got to be something else.
Re: Whats the difference between the audi 225 hp 1.8T and this years 180 hp 1.8T? (vivagarcia)
its got a built bottom end for higher boost
There is a lot of stuff different about it...the motor is not really the same at all...different valve springs and all kinds of stuff.
Re: Whats the difference between the audi 225 hp 1.8T and this years 180 hp 1.8T? (DGMVW)
I was just curious if it was an easy upgrade to 225 or not
The six speed transmission that is in that car can withstand more torque too. It would take some mods to get there, but in order to run at that horsepower all the time you would want a bigger front mounted intercooler...I would think that with a new turbo back exhaust (downpipe to a 3" diameter exhaust), chip, and a turbo inlet pipe, would put you pretty close...Since you have a 2002 1.8t you already have a decent turbo (it's like a combo k03 - k04) so it should be able to get you close.
2
Ah heck I haven't typed this in a while
The 225 has different intake and exhaust manifolds, K04 Turbo (bigger than aftermarket K04's), stregnthened engine block, different pistons and wrist pins, different crank bearings, uprated rod hardware, dual intercoolers, larger MAF, coolant pump that pumps coolant to the turbo after ignition is off, and a few things I can't remember at this time
See less See more
Re: Whats the difference between the audi 225 hp 1.8T and this years 180 hp 1.8T? (JLucchio)
Thank you!
b to the ump
Since knowing how VAG does things does anybody know if it is possible to adapt the TT water pump to a AWD, AWW or AWP motor. Doesn't the Beetle have a similar water pump set up? If so the swap should be fairly simple. It could be a rather economical and more envirotmentally friendly turbo timer.
Re: Whats the difference between the audi 225 hp 1.8T and this years 180 hp 1.8T? (memnuts)
If the TT has a better MAF... can we bolt this MAF onto an AWP?
doesn't the 225 hp TT have a different manifold on it as well?
See less See more
1 - 14 of 14 Posts
