whats the difference between the mk3 chassis and the mk4 .....
1856 Views 9 Replies 7 Participants Last post by  Max Rebo
in refference to "unibody"... i was told that with the mk4 cars vw used a "unibody chassis" what does that mean? and how is it different than a mk1/2/3?
1 - 10 of 10 Posts
Re: whats the difference between the mk3 chassis and the mk4 ..... (joeZX6)
heh.
Mk4 = beautiful
See less See more
Basically, everything from the firewall back is all one piece (i.e., the chassis or frame of the car), excepting the doors, hatch, etc. Everything underneath is one piece, stamped at the factory. The result/benefit is a more rigid chassis with less structural squeaks and/or weak points. That's the idea as I understand it, anyway...
Re: whats the difference between the mk3 chassis and the mk4 ..... (Max Rebo)
Yr absolutely right, the car doesnt ride on a "frame" everything is one piece to which subframes (front and rear suspension) are mounted. This also makes for a lighter car. Where the Mk IIIs not unibody??? I bet they where.
Re: whats the difference between the mk3 chassis and the mk4 ..... (kingpinGTI)
hey would you look at that....theres a black MK3 8v in the background
See less See more
2
Re: whats the difference between the mk3 chassis and the mk4 ..... (LiquidG60x)
i know... totally ups the coolness of the pic...
i didn't even do it o purpose. just HAPPENED to drive by as i was snapping the pic.
Unibody = no true frame. Best examples of body on frame construction are a pickup truck or the RWD Crown Vic/Mercury Grand Marquis. Most cars these days are Univbody.
MK1-4 are all Unibody.
Re: whats the difference between the mk3 chassis and the mk4 ..... (BostonMk4)
Just what i was thinking Boston, I mean a 69 Camaro is unit body, so Im sure VW had it.
mk2,3,4 are unibody and I'm almost positive that mk1 are too
Re: whats the difference between the mk3 chassis and the mk4 ..... (qka2)
I think each succeeding generation of VW gives you better welding, tighter body panel gap tolerances, etc., which is part of the reason the Mk4 chassis is stiffer than that of the Mk3, etc...
1 - 10 of 10 Posts
