Whats the final drive on a 4k? on a stock 92 GTI trans?
440 Views 17 Replies 8 Participants Last post by  Numbersix
What are the gear ratios? I am swapping (tomorrow hopefully) And i was wondering if the final drive is that different. If it is, do i have to change something so the speedo is correct? Is it a hard procedure?
Thanks
1 - 18 of 18 Posts
2
Re: Whats the final drive on a 4k? on a stock 92 GTI trans? (IwannaGTI)
I think that this is correct but please check the tranny code before calling this the gospel
(Taken from the Scirocco.org "gears" link):
ASF,AON,ACN,ACL (8v) final drive is a 3.67
4k final drive is a 3.94
They have a fancy schmancy ratio calculator on that page as well if you wanna find out how many rpm's you will turn to get a particular speedhttp://****************.com/smile/emthup.gif
See less See more
Re: Whats the final drive on a 4k? on a stock 92 GTI trans? ([email protected])
The 4k is a 3.94. You need the correct speedo cable gear. Thats the only piece you need for the speedo to read correctly.
Re: Whats the final drive on a 4k? on a stock 92 GTI trans? (tram)
and where would i get this magical gear??? Is it hard to put in?
quote:[HR][/HR]and where would i get this magical gear??? Is it hard to put in?[HR][/HR]​
Dealer, junkyard. You just yank your old gear of the cable, install the new one making sure the circlip is still on the cable.
Re: Whats the final drive on a 4k? on a stock 92 GTI trans? (Kierowca)
thnaks...what years did the 4k come in?
after August 83 and 84. GTIs, Cabbies and I believe Roccos.
Re: Whats the final drive on a 4k? on a stock 92 GTI trans? (Batan)
GTI rabbits only or all? and does anyone have a pic so i know what i am lookin for http://****************.com/smile/emthup.gif
[Modified by IwannaGTI, 12:10 PM 2-12-2002]
See less See more
Only GTI Rabbits and Cabriolets.
They also came in 84 Jetta Gli's, although those are pretty rare these days.
[Modified by Kierowca, 3:27 PM 2-12-2002]
Re: Whats the final drive on a 4k? on a stock 92 GTI trans? (ajothy)
http://www.kraftswerk.com :
TRANS CODE FINAL DRIVE FIRST GEAR SECOND GEAR THIRD GEAR FOURTH GEAR FIFTH GEAR
FF 3.894 3.455 1.944 1.286 0.909 0.711
FN 3.894 3.455 1.944 1.286 0.909 0.711
FK 3.894 3.455 2.118 1.444 1.129 0.912
2H 3.938 3.455 2.118 1.444 1.129 0.912
4K 3.941 3.455 2.118 1.444 1.129 0.894
7A 3.941 3.455 1.944 1.286 0.909 0.712
ACH 3.941 3.455 1.944 1.370 1.032 0.745
AGS 3.941 3.455 1.944 1.286 0.909 0.745
ACN 3.667 3.455 1.944 1.370 1.032 0.745
ACL 3.667 3.455 1.944 1.370 1.032 0.745
9A 3.667 3.455 2.118 1.444 1.129 0.894
AGB 3.667 3.455 2.118 1.444 1.129 0.912
AON 3.667 3.455 1.944 1.370 1.032 0.745
ASF 3.667 3.455 1.944 1.370 1.032 0.745
ACD 3.667 3.455 2.118 1.444 1.129 0.894
AEN 3.667 3.455 2.118 1.444 1.129 0.894
2Y 3.667 3.455 2.118 1.444 1.129 0.912
AOP 3.941 3.455 1.944 1.286 0.909 0.745
AUG 3.667 3.455 1.944 1.444 1.129 0.894
AWY 3.941 3.455 1.944 1.444 1.129 0.894
CHE 3.667 3.455 1.944 1.286 0.969 0.805
DFQ 3.667 3.455 1.944 1.286 0.969 0.805
The information on http://www.jwsvws.com about how different trannies fit different models is excellent as well. It's under "Technical Information".
[Modified by SeattleGLI, 9:18 PM 2-12-2002]
See less See more
Re: Whats the final drive on a 4k? on a stock 92 GTI trans? (SeattleGLI)
so what is my 92 trans in my 8v?
3
Go out and look
It's on the bottom of the bellhousing, tilted slightly forward, so all you hafta do is stick your head under the bumper. There'll be the 2-3 digit tranny code, and the date code. bring a napkin to wipe the road gunk off so you can read it. Just look for the flat surface breaking the curve.
See less See more
Re: Whats the final drive on a 4k? on a stock 92 GTI trans? (negativl)
i cant...it has a hole in it and its at the mechs
quote:[HR][/HR]Only GTI Rabbits and Cabriolets.[HR][/HR]​
'84 GLi, and Roccos too
so....
If stock, most likely the AUG.
1 - 18 of 18 Posts
