1 - 5 of 5 Posts
Hey guys,
I have a bent rim, just steel, nothing fancy. Anyway, how the hell do you know what the proper offset pattern is. It's a 94 jetta and I wrote down the numbers and God knows what they mean. Any help interpreting this would be greatly appreciated.
Here's what's on there: 6J x 14 H2 ET 45 (14 x 6?? is that it)
2BT
1HM60125A1B
Thanks, Badbrick
Re: Wheel bolt pattern offset (badbricks)
2BT
1HM60125A1B
Thanks, Badbrick
[HR][/HR]​
your wheels are 14" by 6" with an offset of 45
et always=offset http://****************.com/smile/emthup.gif
The above post is correct as far as offset. They didn't mention bolt pattern. The bolt pattern for a 94 Jetta is 4-100mm I believe. Thats if its a 4 lug car. If it has 5 lugs, I dunno.
Re: Wheel bolt pattern offset (Clean97GTi)
quote:[HR][/HR]The above post is correct as far as offset. They didn't mention bolt pattern. The bolt pattern for a 94 Jetta is 4-100mm I believe. Thats if its a 4 lug car. If it has 5 lugs, I dunno.[HR][/HR]​
2.0l 4 lugs (4X100)
VR6 5 lugs (5X100)
1 - 5 of 5 Posts
