Re: Wheel Spacers (Vee Dubb)
Vee Dubb,
I'm pretty sure you have your offsets backwards. Bentley lists the stock offset for the Fox as 45mm and the imprinted offset on my Audi wheels is ET45. My GTI has a ET38.
That said, are you sure they're rubbing the axle? I've tried Snowflakes, Tear-drops, 14" Steelies and a handful of aftermarket wheels on my Fox. I've yet to find a set that rubbed any of the suspension. The only rubbing I ever had (pre-lowering) was on the rear 1/3 of the fender lip. I'd be afraid if you used a spacer this fender rub would become even worse.
But...
Come to think of it, this is the first time I've heard of rubbing in wagons, so I maybe way offbase here.
Vee Dubb,
But...
