1 - 11 of 11 Posts
What size spacers are recommended to run with long beach for front and rear ? Front - 8mm and Rear 20mm or 15mm ? do they have to be hub centric ? and which place sells them and with bolts ?
Re: wheel spacers with long beaches? (paul99)
I have 03 J wagon , I want to push out a bit my rear oem stock wheels "long beaches" to line up with fender or close enough... I hate the look of them right now, hidden in that rear fender..
10mm up front and 15mm in the back should line up the wheels with the fender nicely. Do some searching for pics, I'm sure it's been done lots of times.
As for where to buy from, if you're around the GTA, see the link in my sig http://****************.com/smile/emthup.gif
Re: wheel spacers with long beaches? (Prowler911)
Anyone ever space out stock 16" Montreal II rims (BBS RX 16x6.5 running 205/55R16)? Wheel too small/narrow? Looks weird?
I had thought 5mm was the max for front, before causing steering problems
Guess you'd also need new (longer) lugs...
1 - 11 of 11 Posts
