1 - 2 of 2 Posts
When i get on the throttle in first, then push in the clutch, and shift to second, and then get on the gas some more...then finally let off, there is a loud *clank* like metal hitting metal.
i'm pretty sure one of the mounts is bad. should i just get more stock rubber ones? or upgrade?
what are the prices?
Re: Where and What to get: Engine and Tranny mounts (Schnell-Corrado)
stock front 16v(solid mount). $20 iirc, use an a2 solid right rear, also cheap, i got mine at the yard for 3 bux with the bracket. and filled it will poly to make a solid mount. and i think g60 tranny mount is a solid/ rubber compared to the vr6/hydraulic, or vise versa.
1 - 2 of 2 Posts
