1 - 12 of 12 Posts
Discussion Starter #1
IVE GOT a 95 jetta glx and im lookiong for led tail bulbs...No modification needed. Do you know where I can order them or get the name?!?!??! Please and thanks! http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Re: WHERE CAN I GET A REAR LED KIT? (evolixsurf)
bump http://****************.com/smile/emthup.gif i want some too
FK used to have them, but idk now...
I don't think they make L.E.D. tailights for the Jetta unless it is a custom job (pain in the arse). I know that FK actually made some alteeza looking lights for it a while back and I think they still have them on their site. But alot of people on here dont like them. But do as you want cuz its your car
Re: (druboy)
Quote, originally posted by druboy »
not tail lights! L.E.D. BULBS!!!!!
Re: (brobsrabbit)
Quote, originally posted by brobsrabbit »
take the LED out of a texas instruments graphing calculator and rig that shizz up
you're kidding me right?
here you go.
found it using Google.
Re: WHERE CAN I GET A REAR LED KIT? (ALPHAQGTI)
Really, I'd stay away from that style of LED bulb. When you just have the majority of the lights going outward, you get the 'dot' look inside your housing.
I just converted all the exterior lighting, except headlights of course, to LEDs on my 94 Jetta. Changed out the relay to one that is LED friendly to. If you don't, you get the always fun hyper flashing turn signals! Or you can install load resisters if you are only doing one or two lights, but they get expensive compared to just swapping out the relay.
I basically went around the car and wrote downt he bulb types, then searched companies on ebay. I'd just type in the bulb number, then led,(i.e. 1157 led). Then from the results, I'd look at the design of the bulb. The style that I got look like little towers. they have most of the lights pointing sideways towards the reflectors, so the housings will light up nice and bright.
I probably have around $100 in all the bulbs and the relay. Just keep in mind that you will get what you pay for!!
Here is an example.. Look for the ones labeled 'wide viewing angle'.
http://stores.ebay.com/All-Thi...QtZkm
PM me if I can be any more help.
1 - 12 of 12 Posts
