Re: Where can I get Synthetic Diesel Oil? (towser42)
Take A look I have posted some info fom Amsoil
http://www.djcsyntheticoil.com
1981 VOLKSWAGEN RABBIT 1.6L 4-cyl VIN Code CR Diesel
FILTERS
Oil Filter......LF517
Air Filter......TS33
Fuel Filter......FF834
PCV Valve......N/R
Trans......TF59
BOSCH SPARK PLUGS
LS DELUXE
Wire......NR
Plug......NA
L CUSTOM
Wire......NR
Plug......NA
DELUXE
Wire......NR
Plug......NA
CUSTOM
Wire......NR
Plug......NA
BOSCH WIPER BLADES
Driver side......B40916
Passenger side......B40916
Rear window......B40916
CHASSIS LUBRICATION
0 Fittings, 0 Plugs
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......CC
SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil
Synthetic Blend 15W-40 Diesel Oil
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil
32 to 86°F......30
14 to 50°F......20W-20
14 to 86°F......20W-40, 20W-50
5 to 86°F......15W-40, 15W-50
-4 to 50°F......10W-30, 10W-40
68 to 104°F......40
-20 to 23°F......10W
Manual Transmission,.....GL-4
80W
Series 2000 Synthetic Gear Lube
SAE 75W-90 Synthetic Gear Lube
Automatic Transmission.....AE[1]
Esso Type LT 71141 Automatic Transmission Fluid - Not Available Through Amsoil Click here for more information
Automatic Transmission.....AF3[2]
Synthetic Automatic Transmission Fluid
Automatic Transmission.....AF2[3]
Differential, Front .....GL-5[4]
90
SAE 80W-90 Synthetic Gear Lube
Fluids
Power Steering Fluid.....AF2
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3 - Not Available Through Amsoil Click here for more information
Power Steering Fluid.....PS
Power Steering Fluid - Not Available Through Amsoil Click here for more information
Brake Fluid.....HB
1. Verify fluid installed before topping off.
AE (part no. G 052 162 (-A1, -A2)) is clear-yellow in color.
2. Verify fluid installed before topping off. Alternate Lube
3. Verify fluid installed before topping off.
4. Final drive for automatic transmission only.
CAPACITIES
Engine, without filter..........3.7 quarts[1]
Cooling System, Initial Fill..........7.4 quarts
Automatic Transmission, Initial Fill..........3.2 quarts[2]
Automatic Transmission, Total Fill..........6.4 quarts
Manual Transmission, 4-spd..........3.0 pints
Manual Transmission, 5-spd..........4.0 pints
Differential, Front..........1.7 pints[3]
1. Capacity shown does not include filter. When replacing
filter additional oil may be needed. after refill check oil
level.
2. With ENG automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
3. Final drive for automatic transmission only.
TORQUES
Oil Drain Plug.....22 ft-lbs
Manual Transmission
Fill Plug.....14 ft-lbs
Drain Plug.....14 ft-lbs
CAUTIONS
TRANS/DIFF
Do not add gear oil through plastic plug
on top of manual trans.
ENGINE
Engines with ridge on oil filter flange
need to have the filter re-torqued to 18
ft-lb after running eng for 3-5 minutes.
MISC
DO NOT USE DEXRON III. Verify fluid
installed before topping off. AE is
yellow in color.
COOLING
Models with red colored coolant, only use
VW part no. G012A8DA1. Do not refill or
top-off with any other coolant.
Thanks
SERVICE INTERVAL
http://www.amsoil.com/lit/g1490.pdf
