Scanned the car today and found this code:
16712/P0328/000808 - Knock Sensor 1 (G61): Signal too High
I don't know why I have this code, it drives normal.
I did have a little incident when it was raining hard, I tried to accelarete hard whil ]e it was raining and the car would sputter at higher RPM, something like if your coil pack would go bad.
I was thinking it might have been due to the air filter being soaked with water or even a wet MAF sensor, later the next morning when the car dried up it was fine, and it didn't show any codes...I don't know if that's related with this code now, it's been about a month since that incident.
This is from Ross-Tech's website
Possible Symptoms
Irregular RPM
Drivability Issues
Loss of Power
Engine Damage
Possible Causes
Knock Sensor 1 (G61) Short to Plus
Knock Sensor 1 (G61) Open Circuit
Knock Sensor 1 (G61) improperly torqued
Knock Sensor 1 (G61) faulty
Engine Control Module faulty
Possible Solutions
Torque Knock Sensor 1 (G61) to specifications
Check Wiring and Connections
Check Knock Sensor 1 (G61) and Knock Control
Special Notes
This feature search for unusual (spontaneous) combustion. The sensor detects unusual vibrations and based on that it generates a voltage. Is this voltage outside a certain limit a dtc will be set.
Retrieved from "http://wiki.ross-tech.com/wiki/index.php/16712/P0328/000808"
Possible Symptoms
Irregular RPM
Drivability Issues
Loss of Power
Engine Damage
Possible Causes
Possible Solutions
Special Notes
