Where do I find the steering column bearing?
480 Views 4 Replies 2 Participants Last post by  HyKlas
Where can I pick one of these up at? Thanks.
1 - 5 of 5 Posts
Re: Where do I find the steering column bearing? (HyKlas)
Do you need the upper or the lower? The upper one is just a sleeve that fits into the ingnition switch housing. The lower one acutally presses onto the steering shaft. I replaced mine, but I used the whole steering column.
Have you tried Potterman? I don't know if you can buy these bearings seperate (I would hope so). If not, go get a whole steering column for a U-pull-it.
Re: Where do I find the steering column bearing? (millerwj)
Well, I wasn't aware that there were two. I want to replace as much as possible while I'm in there. Everyone talks about Potterman... Where does this guy work? Seems like you should be able to buy these bearings. I have to pull my rack next week so I'll pull the column at the same time. Maybe I should do my pedal cluster while this stuff is out too. When I have my foot on the brake and press the clutch, the movement from the clutch pedal pushes my brake pedal up. Gas pedal is really crunchy too. That's a whole different thread though. Let me know where this Potterman guy is and I'll talk with him about it. Thanks buddy.
See less See more
2
Potterman = Mike Potter
He runs http://www.parts4vws.com
Thanks Bill. http://****************.com/smile/emthup.gif
See less See more
1 - 5 of 5 Posts
