Re: FV-QR (JDub8)
Silver is the part that never works. Cruise Control module.
The easy way to get it out is to:
1: remove rebar under the steering wheel.
2: remove screen under the fusebox
3: drop fusebox (while at it look for a yellow connection or cable behind fuse box and disable your drl the correct way)
4: remove blank plastic part on the left of the headlight switch
5: push pin on left hand side of switch with a flat screw driver and remove the headlight switch.
6: unplug alarm module
7: Remove 10mm nut that holds the base and gide it down.
8:
Bonus:
http://forums.vwvortex.com/zerothread?id=4016025
Modified by Old Windy at 5:29 PM 7-9-2009
