1 - 4 of 4 Posts
hey guy's a friend is pushing a masive 2 psi of boost so we are going to check for leaks any place that tends to leak after a point of time on the boost system ?
thanks
Re: Where is the best place to check for leaks on the boost system ?? (wolf rocco)
remove battery and squeeze the plastic boost hoses. If theres a hole or its not hard, good chance. Reclamp everything...
silencer box can leak if you backfire it or something the seals can blow out but they usually don't just die on their own.
Re: Where is the best place to check for leaks on the boost system ?? (mrkrad)
ok thats a good idea i will try that
he had a battery leak no too sure if it reached the tubing
and his car does have a back fire
well backfires love to blow the silencer box apart.
Battery acid tends to eat up everything down there. Best if it happens to remove all signs of acid/rust and respray/neutralize the rust.
The rats nest of wiring doesn't help much either.
1 - 4 of 4 Posts
