in the firewall that is... anyone have a picture or description of where the hole may be? I can't find it with the insulation in the way. I am trying to install a boost guage. Thanks!!!!
You can't see it from under the hood unless you remove the battery. From under the dash just look up behind the clutch pedal in the far left side of it . Bob.G
Go through where the ECU harness passes through . . . there will be several rubber "nipples" that you can clip the tips off of to pass the tubing through.
AWE has instructions on their site which show where to pass it through. http://awe-tuning.com/media/pd...e.pdf
Dave
