1 - 4 of 4 Posts
Discussion Starter #1
hey peeps...
i have VDO gauges for my MK2 Jetta. The only gauge that dont work is the Oil pressure gauge. Where is the Oil pressure sending unit located on a 93 VR6 Block? Does it aready have one or do i have to install??
Thanks
Re: Where is the Oil pressure sending unit on 93 VR6?? (Shawn M.)
The oil pressure sending unit to the gauge on my 93 SLC is located on the oil filter housing. there are three ports on top of the housing. On yours, it may be capped since you don't have a gauge originally. All you have to do is remove the allen head screw that caps it and install the sending unit. The port is the lower right port on the housing.
[Modified by Karrambo, 12:37 AM 12-4-2002]
Re: Where is the Oil pressure sending unit on 93 VR6?? (Karrambo)
Excellent! Thank you.
Shawn http://****************.com/smile/emthup.gif
1 - 4 of 4 Posts
