1 - 3 of 3 Posts
I know I need a power and a ground, but where is the closest power wire I can splice into and what should i run the ground to? Also I think i remember someone saying something about a fuse on the power wire? On another note is there any way to fit a rear recaro from a 90 jetta into a 92 gti, i thought they bolted up perfect. DOH!
Re: where to get power for recaros? hlp. (dualgtis)
a wire with a fuse is a power , it can hook up to back of a fusebox when, turn key on and use a test light will turn on
. and a ground wire, mount on any good metal ground . http://****************.com/smile/emthup.gif
It will work!
Modified by veeDUBh20 at 9:18 PM 5-23-2004
1 - 3 of 3 Posts
