1 - 1 of 1 Posts
Used search but still have a question...If you have thread links that would be just as great as a reply!
Where do I put the temp sender for a VDO oil temp gauge when I am also using an Oil pressure guage?
Basically I've confused myself, I know I need to get to the #10 dummy bolt and pop that one out and toss in the TEMP sender? But where do I hook up the pressure sender #16 or am I backwards??? - I've got the 42dd setup with the t-fitting relocator for pressure sender?
Maybe obvious but, temp sender doesn't seem like I need to drain oil - what about the pressure.
Hmmm...I'm glad I already know how to wire, looks like the electrical part will be the easiest part of this project.
1 - 1 of 1 Posts
