1 - 4 of 4 Posts
Which camshaft you gonna run?
Either way, a Techtonics or GIAC 'cam' chip are your only real two options.
But 'canned' tunes are only going to give you 80-85% of the potential power available. I don;t know your location, but seeing as how you are OBDI, you should consider going with Megasquirt and have it tuned with that.
Going with a split purpose cam until you go turbo will, obviously, limit your NA power bottom line. The usual suspects are a TT266* or the more popular, AT270*. Both which you could probably pick up cheap in the classifieds and be a good fast-road cam.
If you got some money to blow, Techtonics is currently developing a 276* for the bigger turbo projects. http://forums.vwvortex.com/showthread.php?5297452-New-Cam-Option-for-all-you-TURBO-JUNKIES!
1 - 4 of 4 Posts
