1 - 13 of 13 Posts
Re: Which offset to run? (Jetta97GT)
15x7? You can run from 25-40 depending on how you want them to sit in relation to the fender - I'd suggest around 30 to 35, you can tuck that pretty good and it won't be too far in, though if you are going to run the same offset all around may I suggest 10mm rear spacers?
lol! now you need them, eh?
H&R makes really good spacers, and come in 10mm, and they can be had from Evolution Sports in WA
Trust me, it makes all the difference in appearance because without, the rears will be sucked in a lot farther than the fronts, and that is just a pet peeve of mine...
No matter what offset you end up with, a 10mm spacer for the rear wheels will make it basically even all the way around - personally, I think a 35mm-ish offset is a good offset to use, so you can tuck the beans out of the Turbos, which is how I think they should be treated!
1 - 13 of 13 Posts
