which position are the fogs on a stock headlight switch?
353 Views 8 Replies 3 Participants Last post by  Pushrods
i need to know which hole the wire for the fog lights is supposed to go to. i thought it was pos. 12, but it didnt work. the only other ones i have open are pos. 3 and pos. 8. any help?
oh, and the switch does have a foglight pull
also, how can i get the wire out of its hole without ripping the wire from the metal female attactment?
thanks
[Modified by pdxvento, 4:13 PM 2-10-2002]
1 - 9 of 9 Posts
Re: which position are the fogs on a stock headlight switch? (JuiceJetta)
but if i pull the wire out, it will rip out of the metal female conection, then im just fu(ked
Re: which position are the fogs on a stock headlight switch? (pdxvento)
FYI: position #12 is for the rear fogs...
Re: which position are the fogs on a stock headlight switch? (DomozitoLK)
its a north american headlight switch, not a euro one. and i am connecting up my rear fogs. so does this mean there is a wiring problem somewhere?
I guess I am not understanding what you are trying to do...could you please clarify.
#12 has no wire in it because the euro switches 2nd pull goes to that wire for the rear fogs. The US switch has no 2nd pull and no way to activate the rear fog.
okay, sorry for the confusion. i have a us headlight switch with the foglight pull, but i have no front foglights(nor do i want them). i do however want the rear foglight, but i am not a big fan of the euro switch. i am trying to get the rear foglight to come on as if i were turning the front fogs on
I would pop a relay into the open positon on the panel under the dash, then use a 12v test light to probe each of the wires on the harness. they're like 5 bucks at Radio Shack.
The one you want will definitely have a wire in it. This is because all the cars are prewired for fogs up to the main lighting harness in the front of the car. Tap/splice into what ever wire you find is the correct one.
Good luck. http://****************.com/smile/emthup.gif
See less See more
Re: which position are the fogs on a stock headlight switch? (JettaGLS)
thanks bro. i think the problem might be that there is no fuse for a foglight, since originally, there was no foglights(GL). so ill toss one in, and well see.
See less See more
quote:[HR][/HR]thanks bro. i think the problem might be that there is no fuse for a foglight, since originally, there was no foglights(GL). so ill toss one in, and well see.
[HR][/HR]​
Well, you'll need either a relay or a jumper. I'd just use a relay since you can pick one up when you buy the test light for another 5 bucks.
See less See more
2
1 - 9 of 9 Posts
