1 - 11 of 11 Posts
Re: Which WB02 should I get? (84_GLI_coupe)
Quote, originally posted by 84_GLI_coupe »
I've been wanting an LC-1 for a while, any experience with lag time on it?
none, even reading the afr right in MT http://****************.com/smile/emthup.gif
great setup, just be sure to put a 470ohm resistor between your analog output and the o2 input on MS, otherwise the MS almost always fries your LC1
zeitronix also makes a good setup, but its a bit more money than the LC1
Moderator
Re: Which WB02 should I get? (ValveCoverGasket)
Quote, originally posted by ValveCoverGasket »
Interesting - I've been running my LC1 with my MS for almost 1 year - no resistor , daily driven and zero troubles.
Discussion Starter · #7 ·
http://www.innovatemotorsports...age=1
Would this be all I need? Megatune will give me a display reading correct? Is it necessary/recommended that I have a display gauge in the car for constant monitoring of my A/F?
Where is the best place to mount this? In the original location in the 4-2 manifold or drill a hole in my dp and weld a bung on?
Re: Which WB02 should I get? (Rankin)
id put it at the collector if youre not running a turbo, and about 6-10 inches after your turbo if you are.
no need to constantly monitor it, a narrow band and a cheapo afr gauge will work fine after its tuned. MT will display the actual afr so no need to buy a seperate display
1 - 11 of 11 Posts
