Which wheels will fit my Jetta GLX?
345 Views 3 Replies 2 Participants Last post by  LotusSyfn
I have a 1999 (A3) Jetta GLX VR6 and I am now looking for some wheels for it. I am kind of looking at either OZ's or SSR's, but the problem is, I have the H&R Cup Kit on the car and I am afraid to order anything before I know if the wheels will fit. So, does anyone know of any specific good-looking rims that are maybe 16's or 17's that will fit with no problem?
Thanks
1 - 4 of 4 Posts
Re: Which wheels will fit my Jetta GLX? (Vento1999V6)
16 or 17in wheels will fit fine as long as the offset is anywhere from 35 to 38mm offset. I would suggest you go no wider than 8" width... use the offset range i gave you and you should be ok. Also it depends on what tire size you use... which size are you more likely to get?
-Mary
Re: Which wheels will fit my Jetta GLX? (LotusSyfn)
I think I would really rather 17's
17x7 - 17x8 use 205/40/17 tires as long as you use that set up you should avoid any tire rubbage problems. OZ and SSR are an excellent choice!
-Mary
1 - 4 of 4 Posts
