Re: Who can install a Peloquin or Quaife in Pittsburgh? (gtschallenge)
you might be best to send it out.
I've seen local trany shops that install the diffs yet they don't take the time to reshim it properly.
it is a time consuming pain and no dealer stocks the shims.
If it is not shimmed correctly you end up with a wobbly diff.
but beware brand new output flange seals make a diff feal tight in the case till they wear a bit.
if it was a 020 I'd help you out but i've never torn down a o2a.
best of luck http://****************.com/smile/emthup.gif
