1 - 4 of 4 Posts
Re: who has CONDENSATION in there MK4 lights ??? (VR6ish)
It use to condensate in the beginning but not anymore. I didn't do anything at all either.
And it's really humid in Miami - kinda feels like a laundry matt at times...swamp style.
Now you can get some clear silicone glue and spread the good stuff around the edges where the glass meets the plastic housing to make sure there are no leaks. Thats what I would do
The newer lights should have the vent tube (small rubber tube, about 1/3" in diameter) that helps reduce fogging quite a bit. You may also want to check that the bulb is fully seated, as even a little bit of a gap can make it fog up. http://****************.com/smile/emthup.gif
1 - 4 of 4 Posts
