1 - 17 of 17 Posts
brakes on my car are gone all around... i am considering doing this upgrade while my car is in the shop...
i am looking for pictures, testimonials, etc etc..
i know that the rear brakes aren't responsible for the majoriety of the braking that my car does every day, but i also don't wanna look like an idiot with the drilled/slotted front rotors i am planning on buying with black drums on the rear... looks are important to me just as they most likely are to you all. but if i get some added performance from the swap, i'd make me even happier.
i tried search and found a couple threads, but i am looking for more opinions on the subject before i take the plunge...
thanks peop.
this is what they will be going on.
Modified by Feyd at 11:37 AM 2-15-2004
Modified by Feyd at 9:54 PM 2-15-2004
Re: Who here is running the ECS drum-to-disk conversion?? (Feyd)
would like to read more about it too so here's a bump.. http://****************.com/smile/emthup.gif
Re: Who here is running the ECS drum-to-disk conversion?? (dstdub)
and one from me too... http://****************.com/smile/emthup.gif
im actually about to do g60 rears on mine. thats the way to go imo. cheaper i bet
Re: Who here is running the ECS drum-to-disk conversion?? (gwarballs)
I believe passatrcr has the kit. I did the vr6 conversion, and am quite happy with mine. 1 of my stock drums had a horrid brake fluid leak...
Re: Who here is running the ECS drum-to-disk conversion?? (HockeyDork)
I used the ECS kit. It is TOP NOTCH!!!!!!!! It included everythig needed except brake fluid, which they have a pretty good price on so I got that from them too. It all went on without a hitch and have had exactly zero problems since day one. http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
Re: Who here is running the ECS drum-to-disk conversion?? (askibum02)
this could be a stupid question but how do you know that the rear discs are actually working(not using the e-brake) right since the fronts handle more of the stopping? how did you adjust the rears?
Banned
Quote, originally posted by dstdub »
you'll know...trust me
Last summer I did my front brakes, w/ new slotted rotors and mintex pads, drove around for a bit, and then noticed that my braking performance was getting downright dangerous. I checked my fronts and they were of course in great shape. When I checked the rears, they were completley gone and in fact the began to shriek on the drive home. Long story short, I fixed the rears and braking performance was completely restored.
Discussion Starter · #9 ·
Re: Who here is running the ECS drum-to-disk conversion?? (VAGinitis)
this is great guys... keep em comming...
anyone, have any pics??
how do you regulate or set the correct stopping power that goes into the rears? or does is there a part that controls that already?
Banned
What I have been wondering
Re: Who here is running the ECS drum-to-disk conversion?? (ventovolkswagen)
unless you have ABS in your car you will have a proportioning valve mounted to the rear beam in the car. This has some amount of adjustability to it. I would leave it stock and see how that works then adjust from there.
From what I have seen, all MKIII's and corrado's etc have the same size rear discs. Something around 9" and solid rotors. The kit from ECS is pretty good. If you are upgrading I would say might as well upgrade to MKIV calipers. They are aluminum and are supose to be less prone to seizing up, plus can dissipate a little more heat from those little pads in the rear.
FYI, I did the swap last summer, and left my proportioning valve exactly where it was, and I have almost perfect braking bias front to rear. went to an autocross even and watched a video of it afterwards. The inside rear tire would lock up just as I was turning while still hard on the brakes. Dont' notice a huge difference performance wise, but sure it did something. and definatly a http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif for looks.
Re: Who here is running the ECS drum-to-disk conversion?? (1997 Golf GL)
good info! http://****************.com/smile/emthup.gif
Discussion Starter · #14 ·
Quote, originally posted by 1997 Golf GL »
i wanna see what this kit looks like on a car...
The kit from ECS is exactly what a stock car has with 4 wheel disc brakes. Nothing is upgraded on them except if you get different rotors or MKIV calipers. But disc size is all the same as stock.
DubPhreek said:
GO get the rear beam from a passat 1.8.
and the brake cables come from a Scirrocco 16v (as I recall)
new bearings 5.00 ea X4=20.00
new grease =5.00 (top of the line)
new rubber grease caps = 3.50 ea =7.00
new metal grease hubs 4.00 ea =8.00
Banned
i like my rear drums only for the fact that i get less brake dust on my rear wheels, when the fronts get dirty i just switch them until they are all dirty, then wash...
1 - 17 of 17 Posts
