I have tried sooo many combinations and none of them work. mbc before N75F/J, mbc after N75f/j ( I just get big spikes (15psi) then it settles back to 10psi.
Running the mbc alone set to 13psi works great for a little while then I get soft limp mode on and off. It does this even if I set the mbc to 11psi.
Unplugging the N75 seems to cause immediate limp too. Seems to me that a mbc isn't going to cooperate with the 2003 AWP engine.. Unless perhaps I clamp the MAP signal? Not too sure I want to do that yet....
Any info here would be appreciated!
Modified by SnowGTI2003 at 4:20 AM 1-8-2004
