1 - 3 of 3 Posts
My 2002.5 GTI VR6 24v has developed a squeak in the front suspension. I changed the strut mounts and strut bearings with no improvement in the squeak, although the struts feel better. The next attempt was to disconnect the left front swaybar mount and put the wheel back on. No change. So I reconnected the sway bar and kept looking. Could the squeak come from the control arm bushings?
I'm lost. Any suggestions out there????????????????
Re: Why is my car squeaking??? (sntx)
Quote, originally posted by sntx »
You don't need to start more than one thread about it. Good luck finding the problem.
Vicious...
Check the sway bar bushings. That would cause a squeak. Or the sway bar links too. Lube em up or change em.
1 - 3 of 3 Posts
