1 - 20 of 22 Posts
I have a 3" Y manual Dump tube. I Was looking into getting the electric butterflies for my set up. Quicktime sells there fore $150 ad McCord has thiers for $110. Wich to get? Whos has one and any comments on theirs? Thanks
QTec
McCord
Modified by BoostedGolf02 at 2:21 PM 5-18-2004
Modified by BoostedGolf02 at 2:22 PM 5-18-2004
Re: (GTiVdubber)
Quote, originally posted by GTiVdubber »
one broke mccord here. . . about 5k miles on it
damn what happened w/ the McCord?? I was looking into getting it cause it was 40 bucks cheaper
Re: (BoostedGolf02)
40 bucks you cheap sonna ..............im just kiddin you little rascal you.
ummm.......yeah i really have no input except for that both more than likely do the same thing. actually i have dump too and i was thinking of using the mccord.
what did happen?
Discussion Starter · #7 ·
Re: (GTiVdubber)
the plate that rotates to open and close the dump broke off from the bar that it was attached too.
Did they at least replace it for you...
Banned
Re: Wich brand Electic Dump Tube to go with....? (BoostedGolf02)
Got myself the Quick Time Performance switch and had it fabbed into a 2.5"SS Polished exhaust. We all enjoy pics.
Re: (GTiVdubber)
this happened to my mccord too... but when it happened i was trying to close the plate while at wot so that had to put alot of stress on the plate. mccord sent me a new one right away and i attached it with some strong little bolts and a little weld. no problems as of yet.
Re: (BoostedGolf02)
I went through 2 mccord power plates. The design is terrible and the service is comparable. I have even taken the plate apart and it really is poorly designed. Not sure about the QuickTec one though. Good luck.
Re: (Sleeper GM)
Quote, originally posted by Sleeper GM »
Not good. I just got my McCord yesterday
Hopefully I have better luck
Banned
Re: (trbochrgm02)
Quote, originally posted by trbochrgm02 »
better weld the through bolts to the rotating member. they are bound to back out.
had my plate come off of the car and called Quick Time right away. Within 20 hours of my call I had a new one with two backups with hardware at my door.
What service! http://****************.com/smile/emthup.gif
Thanks again Quick Time PErformance http://****************.com/smile/emthup.gif
Re: (bluanutonu)
I had a mccord...it was junk....same problem as above....the plate fell off....more then once.... one time when i was 8 hours from home
i called them and this was their answer...."our application isnt meant to stand up to the heat of turbo cars".... what?
So I called the guy at quicktime..... he knew who I was from vortex when i discribed my problem with the mccord....."yeah, i saw your thread, their product is a joke!"
long story short....i bought the quicktime....loved it... endedup going with a full 3" TB system and selling the dump.
the guy who i sold it to is now selling it....its posted up here:
http://forums.vwvortex.com/zer...age=1
-Beaker
Re: (Beaker In RPG)
as far as exhaust leaks, anyone get any.? Is it 100% shutoff when closed? Plus does anyoine get O2 sensor faults while running it wide open? http://****************.com/smile/emthup.gif
Banned
Re: (BORA 18T)
I have a minor leak than can be mended evfery so often by using the high temp red silicone paste.
While running the dump open for longer than five minutes or so I do get a CEL. It goes out after closing the dump and driving the car for a while. At least 30 miles or so and after turning the car on and off at least three times.
Car runs horribly rich while CEL is blazing my face. Huge loss of power. Found that the key to using this item is to only use it for short periods of time. I open the dump to cool the turbo after repeated blasts.
1 - 20 of 22 Posts
