1 - 4 of 4 Posts
I recently bought a 95 GLX, on my way home I noticed that everytime I let of the gas or gently applied the brakes that my car would pull to the left, even my steering wheel would turn.
When I got home I noticed that the suspension was all hacked up, so I bought a nice Bilstein setup... e.g.even though this has nothing to do w/ it ( I jacked up the rear beam to put jack stands under the car, once in position I lowered the jack and the whole beam fell right to the ground, nothing was holding the suspension up top)...
So after the complete install it's still doing the same thing.
I'm thinking stuck caliper, but it happens when I just let off the gas too?
Play in axles?
Please anyhelp, this is getting dangerous!!!!!
Re: Wierd steering problem HELP (jkcorradovr6)
95 jetta 2.slo
mine is in the shop right now for the same reason. i've had the problem since the car was lowered. so something during the suspension work has caused my steering to be off. for the bashers!!! my car is aligned... have had VW confirm the alignment so the issue is definitly suspension/steering related. i have a hard time believing it could be brake related... but YOU NEVER KNOW!!!!!!!!
1 - 4 of 4 Posts
