Will 225/50/15 fit on stock vw 5x100 rims ?
708 Views 5 Replies 3 Participants Last post by  TurboDave18t
225/50/15 Yokohama Advan A032R
Found a set for sale which would be sweet for auto-x. They're a little wide but for the track will this work ? Stock is 205/50/15 so its not TOO far off.
1 - 6 of 6 Posts
Re: Will 225/50/15 fit on stock vw 5x100 rims ? (Lexi)
Stock steel rims that is [ don't know the width off-hand]
Yes, I believe they will fit, if the stock 15's are 6 inches wide.
Stock size is 195/65/15. btw
Re: Will 225/50/15 fit on stock vw 5x100 rims ? (TurboDave18t)
Stock on my 95 Jetta GLX is 205/50/15
See less See more
The tires will fit the wheels . . . however they will most likely rub the fenders. The next problem will be how it hurts your performance, the tire is taller as well as wider and will act like a change in gear ratio . . . my advise is don't bother with them. Save your money for a set of S03 Poles!!!
See less See more
Oops, sorry man.
For some reason I thought you had an MK4 Jetta.
See less See more
1 - 6 of 6 Posts
