1 - 8 of 8 Posts
I found a 16 valve and a 5 speed transmisson out of what i think is a b3 passat the clutch cable looks like it is in diff place. I need a trans and the guy only wants 50 bucks for the motor and 50 for the trans. And i already got the 14 inch le castlletes for 50 bucks.
What moddifications do i need to do in order for this trans to work in my rabbit? i think the tranny is cable shift as well will that just swap over with my existing linkage or is that a completely diff setup? Please help me out cause i would like to swap my 1.8 cis for some 16valve megasquirt but i dont wanna drop the 16valve in on a bad 020 tranny also i hope the tranny will be geared a little lower cause 4k at 60 in fifth gear is not cutting it. So thanks in advance for your help.
Re: (JaymesW)
16v b3 passats have 02a transmissions. so, no it will not bolt right into your car, you need to convert to a hydro clutch among other things.
Re: (s-rocc)
Quote, originally posted by s-rocc »
Hydro clutch can easily be solved though nowadays.
For instance, i use my cable with this home-made aparatus:
You will also need custom drive side and rear mounts, both of which are mass produced by vortex users.
I take it though, that if you are the type to be looking for good deals, a 250$ mount is not something you are willing to consider, if i am wrong, then i apologize.
If you choose to buy it and need help making a bracket like mine (to make your cable function with a hydrolic tranny) don't be shy to send over a pm
Re: (derek_mk1)
^^That's a pretty sweet custom slave cylinder, pretty creative http://****************.com/smile/emthup.gif
You can also use the clutch cable setup from a Eurovan on a 02A.
Here's a good link on the subject:
http://forums.vwvortex.com/zerothread?id=1060826
Re: (silvervdubs99)
I am very interested in more details about the hydro/cable 02a clutch adapter. I am looking to go the same route on an 02a swap into a mk3 golf aaz w/ cable clutch.
Any pictures of it installed? dimensions?
cheers,
Alan
1 - 8 of 8 Posts
