1 - 8 of 8 Posts
Re: Will a 3 spoke steering wheel from a MK4 fit my Jetta???????? (A3VR6)
quote:[HR][/HR]You will need the 3-spoke steering wheel from the Mk3.5 Cabrio.
-VA[HR][/HR]​
And it looks good too
-VA[HR][/HR]​
Yup...the Mk3.5 Cabby wheel is plug and play...it took me all of 20 minutes to do the swap http://****************.com/smile/emthup.gif great interior upgrade
Re: Will a 3 spoke steering wheel from a MK4 fit my Jetta???????? (96JettaTrek)
That I am not exactly sure of...but it is the 'spindle' that is different...the number of 'teeth are different I think.
Anyone want to validate this just to make sure?
Thanks,
quote:[HR][/HR]can you email me the how-to instructions? [HR][/HR]​
sure thing...i'll post 'em here too, just cause i am bored
the removal of your current Mk3 4 spoke wheel is really easy. here's how i did it:
1)remove negative cable off battery
2)locate the allen bolts on the back of the steering wheel(they are at about 3 and 9 o'clock positions on the back)
3)using a #5 allen wrench, loosen the bolts (even though they will be completely loose, they dont come off the wheel)
4)slowly lift out the airbag from the wheel
5)using a butterknife, wedge it between the yellow wire connection from the airbag
6)notice the little 'dot' at the top of the wheel...it is minute, but that dot is 'dead top center' for the steering wheel.
7)using a 24mm bolt, unscrew the bolt holding the wheel itself from the column
now for the installation of the Mk3.5 steering wheel:
1)locate the 'DTC' dot on the column
2)locate on the steering wheel an indention that looks like an arrow pointing down; line the dot and arrow up and slide wheel onto the column
3)tighten the 24mm bolt onto the steering wheel
4)clip the yellow airbag wire onto the back of the new airbag
5)push the airbag into the wheel - it will 'click' into place
that's it! it took me about 20 minutes total to remove the old one and install the new wheel. if you have any questions let me know.
happy dubbing-
steve
disclaimer: please dont hold me reliable for any damage to your car or injury to yourself. these are the steps i did and it worked fine for me. thanks!
1 - 8 of 8 Posts
