1 - 4 of 4 Posts
Discussion Starter #1
I wish to swap the auto out of my 91 Passat 16V and use a mk4 manual EHA trans which is a close match to the original ATA 020 trans. So the question is will a mk4 manual EHA trans mount to the 9A without issue. Do they both have the same bolt patterns? Doing work arounds and mods to use the clutch master in the Passat.
Thanks
Discussion Starter #3
1.8T flywheel and clutch? I hope will work. I picked up a 1.8T EHA trans along with the clutch and flywheel. Hopefully they bolt up as well.
It's typically the trans that decides on whether the flywheel will accommodate but if it's DMF there's some conflicts at the block too IIRC. You would be better off with SMF if you can go that route.
Steve
1 - 4 of 4 Posts
