Re: Will et 40 offset on a 16x8 wheel fit? (turboit)
you will most likely need spacers in the rear to clear the coilovers. that gives you about 5.6 inches of backspacing i think you will need to be closer to 5 inches or less backspacing to clear the suspension
I pritty sure they wont fit. Well at least not on my car. I have H&R coilovers with 17-8 et 35mm rims and and I had to use 8mm spacers in the rear to clear the suspension. With 8" wide rims I wouldn't go any smaller the a 35mm et
PS My friend has the Wolfsburg Edition 16" (et 42mm) rims on his mk3 VR6 and he had to use 5mm spacer to clear the stock front calipers.
Re: Will et 40 offset on a 16x8 wheel fit? (AlexiGTIVR6)
WILL NOT FIT...i had an et of 41 on my 18x8 and wouldnt clear the coilover, need a 10mm spacer fronts wont work either, even with 35mm offset i still needed 10mm spacer....so i say if you run 15mm in the rear and a 10mm in the front that would be sick
thats funny.....I run 17x8 with 215/40s and I really dont need anything...I run 38s in the front and 35s in the back....I think different wheels measure different...I do run a 5mm spacer in the rear just cause I'm close...but thats to be safe...and I have bilstein coilovers..............
Re: Will et 40 offset on a 16x8 wheel fit? (CLUMKIS)
quote:[HR][/HR]thats funny.....I run 17x8 with 215/40s and I really dont need anything...I run 38s in the front and 35s in the back....I think different wheels measure different...I do run a 5mm spacer in the rear just cause I'm close...but thats to be safe...and I have bilstein coilovers..............
VW Vortex - Volkswagen Forum
