1 - 4 of 4 Posts
I had the question asked to me, "Would my NA Golf A3 lights work in a Euro Rad support". Then I can add the MKIV lights later.
Does anyone know if the NA lights will work in the Euro Rad, or is it the same as the Euro lights working in a NA support=MODIFICATION????
thanks,
chris
Re: Will NA lights work in a Euro Rad??? (Crunch007)
the lights will clear the rad support fine, but all the mounting points (screws that hold the lights in) are different. You would need to fabricate brackets to correctly mount the NA lights.
Re: Will NA lights work in a Euro Rad??? (HappyVdubber2)
dont hack up the euro rad to fit n/a...it will only be i pita when you wanna fit your new lights in. The mounting points are all different and the depth size too.
1 - 4 of 4 Posts
