will the 1.8 16V crankshaft bolt up directly on a 2.0 16V block?
499 Views 4 Replies 5 Participants Last post by  Donkey
what will the compression turn out to be? which connecting rods should do i use? and what will the rod ratio become?
1 - 5 of 5 Posts
Re: will the 1.8 16V crankshaft bolt up directly on a 2.0 16V block? (idt512)
heheh i dunno, but the rods are the same.
i've heard the cranks are not interchangable. Don't know why. I'm sure somebody who actually knows what's up will pipe up here soon...phobia16v where you at?
Re: will the 1.8 16V crankshaft bolt up directly on a 2.0 16V block? (MyGTI)
ummm, the stroke is way different.
you'd have a compressions ratio of about 3:1
See less See more
Re: will the 1.8 16V crankshaft bolt up directly on a 2.0 16V block? (rockin16v)
it would be 7-5-1
1 - 5 of 5 Posts
